outdoor ltg-BUG rating
Toros
Tujunga, CA
Hello
Anybody knows about outdoor wall mounted fluorescent light with good, #1 BUG rating, type of stray lights
"B":
back light, lights directing to back of fixture
"U":
up light
"G
": glare, front light, annoying light emission bothering drivers......
(note that I have to have the manufacture data, specification also to proof )
Thank you
Hello
"B":
"U":
up light
"G
Thank you
Can you post a link to it?
Also can you provide more information?
I don't think the OP has anything to share, that is what he is askiing today.
ELEVATOR CAR LTG
ELEVATOR CAR LTG
Hi
where does code say about elevator car lighting circuit to be dedicated and has to be run through a disconnect switch mounted in that elevator machine room.??
Thanx
Hi
Thanx
It's in the State Bldg Elevator Code. It's been standard around here to disconnect all services to the Elevator. The Cab power is different than lights and different than a GFCI. The New style is to have power up at the top of the shaft, and that will be separate than the pit circuits.
Just ask the E=Man what he needs and when you can work in there, I've also asked for arrangement advice. It'll go a whole lot smother. :)
Hello
"B":
"U": up light
"G": glare, front light, annoying light emission bothering drivers......
Thank you
Outdoor lights should be closed for bugs. Malibu is a possible choice.
Someone wrote a nice lamp comparison where heat and spectrum played a part in respects to bug attraction. I had also read
where the one LED manufactured wanted to change the measurement of light in respects to Lumen s and other measurable
presentable qualities.
I did see where LED is now out in single elements for stairways and could be used for other backlite aspects.
That's a funny comparison when you think about it... "bugs"
