Outdoor Panel Mounting requirements
klaatu
Texas
Engineer
I'm installing a 100A sub panel away from the primary panel. I will need to erect a structure to support the outdoor panel. What are the requirements for such a structure. I have seen it as simple as a 4x4 post sticking out of the ground, with the panel mounted to it.
I was thinking about using this: http://www.lowes.com/ProductDisplay...&catalogId=10051&productId=3651840&cId=detail
It provides weather protection, is cheap, I don't have to build it, will last 10+ years, is electrically insulated. I would screw a sheet of plywood on the back wall and mount the panel to the plywood.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
