- Bremerton, Washington
- Master Electrician
For a propane powered 47 KW generator, installed outside on a pad:
Is there a minimum distance from the regulator (on the feed line from the tank) to the generator - IE a fuel gas code requirement for the regulator to be a certain distance from combustion sources?
