outdoor rated ground bar?
anbm
TX
Designer
If the ground bar is going to be located outdoor, does it need to have an enclosure / cover?
does any manufacturer make outdoor rated ground bar?
K8MHZ
Like one of these:
Jraef
Moderator, OTD
Electrical Engineer
Commercial central plant, they want to install the main gear and ground bar on slab first, energy it... and build the pre-fab building to enclose them
next year.
Um, is the gear rated for outdoor use? If so, why can't the ground bus be located inside of the gear?
infinity
New Jersey
Journeyman Electrician
next year.
You cannot use the intersystem bonding bridge in the photo in post #3.
It's a good question, I wonder if the ground bar is required to be listed for wet locations.
