Matt Mckenzie
- United States
does an outdoor sewage pump with a dedicated circuit have to be gfci protected?
NC has an amendment that allows us to forgo the GFCI but the NEC does not have an exceptiondoes an outdoor sewage pump with a dedicated circuit have to be gfci protected?
Good point - I assumed plug in and 120VHard wired or plug in?
There ya go. All bases covered.Some of this already covered by others:
Is is supplied by a receptacle? Hard wired wouldn't require GFCI.
Where is receptacle? Inside a covered pit, isn't exactly an outside receptacle.
What voltage? 120 volt 15 and 20 amp receptacles are the only ones that will require GFCI protection.
To which I may ask for more substantiation. If it were on dwelling unit property - he may have a little more to go on by calling it an accessory building, though that is also questionable.If I tried that here the inspector would laugh and laugh and them say 'no really, that gets a GFCI '.
(2) Garages, and also accessory buildings that have a
floor located at or below grade level not intended as
habitable rooms and limited to storage areas, work
areas, and areas of similar use
I was questioning whether it actually is an accessory building.Yes and accessory buildings at grade level would also need gfci
GFCI protection is for people protection. Who crawls into a sewage pit on a regular basis? This structure is not intended for human habitation.
They may also run extension cords through door/window from non GFCI protected outlets in the house.No but if it only has a door or a lid and is outdoors then a home owner may open it and use the receptacle for a weed eater or other things
