I got called out to clean up a residential outdoor sub panel that services an RV location. The panel looks like it used to be an old temp panel. The Neutral is bonded to the frame so there is no easy way to separate Grounds and Neutrals. The EGC in this case is #6 bare copper run in the pipe with the feeders. All the N and G's land on the same busbar.
What is the best option here? Just leave everything as is?
Additionally, there are no ground rods but that is a separate issue.
