Outdoor surface mount fixture on a raised box?
dp1978
New member
USA
I am installing some 120v lighting to an outdoor deck and pergola. I will (obviously) run everything for wet locations THWN/raceway/boxes/fixtures all outdoor listed.
I want to put up some fixtures on the vertical posts of the pergola, I intend to go up the back of the post with conduit (rigid NM PVC) and 90 through the post into a round lighting box mounted on the front surface of the post.
I want to use fixtures like the type used by the front door of a house (wall mount), but all the fixtures I can find are for flush wall mounting with a recessed box (the fixture is oversized to rest/seal on the siding of a structure). Since I am mounting to a 4x4 post, recessing the box isn't really an option. I know that there are some floodlights that mount to a raised box, but that isn't what we're looking for. I can't be the first person to want to do this, so I am sure there exists some sort of box adapter or other solution to allow the use of a standard wall mount fixture on a raised box, I just can't find one.
Any thoughts are appreciated.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
