590.2 All Wiring Installations
(A) Other Articles Except as specifically modified in this article, all other requirements of this Code for permanent wiring shall apply to temporary wiring installations.
Temporary installations of electrical equipment must be installed in accordance with all applicable permanent installation requirements except as modified by the rules in this article. For example, the requirements of 300.15 specify that a box or other enclosure must be used where splices are made. This rule is amended by 590.4(G), which, for construction sites, permits splices to be made in multiconductor cords and cables without the use of a box.
(B) Approval Temporary wiring methods shall be acceptable only if approved based on the conditions of use and any special requirements of the temporary installation.
The provisions of 590.2(B) require that all temporary wiring methods be approved based on criteria such as length of time in service, severity of physical abuse, exposure to weather, and other special requirements. Special requirements may range from tunnel construction projects and tent cities constructed after a natural disaster to flammable hazardous material reclamation projects.
590.3 Time Constraints
(A) During the Period of Construction Temporary electrical power and lighting installations shall be permitted during the period of construction, remodeling, maintenance, repair, or demolition of buildings, structures, equipment, or similar activities.
(B) 90 Days Temporary electrical power and lighting installations shall be permitted for a period not to exceed 90 days for holiday decorative lighting and similar purposes
So as you can clearly see an inspection is required as well as a permit.
