I need to spec a 480V to 240V transformer that will be located outdoors.
I'm a little reluctant to use a dry type. I know they are rated 3R (with weather shields), and are frequently placed outside, but I'd like to spec something a little more rugged and waterproof.
I would spec a liquid filled transformer, but I don't know if anyone even makes those for low voltage (<1000V). Was also thinking about a epoxy encapsulated transformer, which I think is also called a cast resin xformer.
Does anyone know if they make liquid filled low voltage xformers?
Pros or cons to the epoxy or resin xformers?
thanks in advance.
thanks in advance.
