Mark Patterson
- Three Lakes Wi
I would like to fine out what is the amount of volts from the neutral to the eq. grounding port in a reguler 110 comerial duplex out can be. I just some repairment from the zerox company tell me that it wshould never be over .5 volts or if it is it can take out the control boards on there copy and fax machines. Can you guy tell me if over .5 volts is too much and is there somekind o APC of something that I can control the grond voltage going to these untis..
