I am trying to understand that the specification data for L21-30R says 4 pole so I want to know is it possible they connect 3 hot + 1 neutral + ground and use 3 pole breakersThere is a 3 phase receptacle fed from a 3 pole circuit breaker so what do see as a problem? The receptacle has no neutral?
Does that mean there is no neutral wire or is it possible there is neutral but no switch
Can you connect the L21-30R, 120/208v, 3 hot + 1 hot + 1 ground in 3 pole breaker?An L21-30R is a three phase with neutral and ground receptacle. For it to be properly wired you would need the three phases and neutral from the panel. 208/208/208/120 with ground.
That said, someone could certainly just wire it without the neutral, but that would create a situation where equipment requiring the neutral could be plugged into the receptacle with not so good consequences.
This is why we have specific receptacle configurations- so only the correct plug can be inserted in the receptacle that provides the proper voltages and current for the equipment.
-Hal
Sorry I missed the neutral. Can you connect the L21-30R, 120/208v, 3 hot + 1 hot + 1 neutral + 1 ground in 3 pole breaker?
Perhaps you should have an electrician do this for you.I am trying to understand that the specification data for L21-30R says 4 pole so I want to know is it possible they connect 3 hot + 1 neutral + ground and use 3 pole breakers
Yes an electrician will be installing this. I am designer trying to understand the data spec specifying 4 pole, 5W and the existing outlet installation has 3pole breaker that’s where I got lostPerhaps you should have an electrician do this for you.
-Hal
You need to provide a 5-wire circuit: ABC-N-EGC. The ABC is fed from the 3 pole circuit breaker. The other two conductors are from their respective buses in the panelboard. The EGC can be a metal raceway if applicable.Yes an electrician will be installing this. I am designer trying to understand the data spec specifying 4 pole, 5W and the existing outlet installation has 3pole breaker that’s where I got lost
Thank you. That explains it.You need to provide a 5-wire circuit: ABC-N-EGC. The ABC is fed from the 3 pole circuit breaker. The other two conductors are from their respective buses in the panelboard. The EGC can be a metal raceway if applicable.
You're welcome.Thank you. That explains it.
This is just a confusion of terminology.I am trying to understand that the specification data for L21-30R says 4 pole so I want to know is it possible they connect 3 hot + 1 neutral + ground and use 3 pole breakers
That’s what it throws me off at firstThis is just a confusion of terminology.
They consider the neutral to be a "pole" of the receptacle; the breaker does not include the neutral.
