It does not specifically list closets, but it does at the end of the list state, "and similar room or area of dwelling units". Including area opens the interpretation enough for the inspector to include closets. Choose your battles wisely....
I see 210.52a 1 does not list closets as required area.
FWIW, IMO, a standard size clothes closet is not close to a similar room as the others.
OTOH a large walk in closet with cabinetry and such I would say pretty similar.
Clothes closets have changed that is for sure.
The rooms and areas that it does list have the following characteristic in common: The owner can use a receptacle outlet to either plug in a radio and listen to music while they are working in that room or plug in a floor lamp next to a chair and read in that room. A closet does not share that characteristic. That is my basis for not considering a closet to be a "similar area" to the items on the list. I can't think of a single thing that I would plug into a receptacle outlet that is located in a closet.I see 210.52a 1 does not list closets as required area.
A vacuum cleaner if it is a really big closet and the vacuum has a short cord?![]()
Tell him to provide a code reference. The only requirement for closets that I know of is for light fixtures near shelves.
410.16
It is not a required luminaire. The code lists what types permitted/not permitted and where they CAN be mounted.
I once had an argument over a large closet as to whether it needed an ingress/egress window. :jawdrop: I had wired receptacles due to the size.
Frank DuVal
False, and this is one I'd argue over. Lights, yes, receptacles, no. Both are "outlets".
lighting is an option not a requirement -- I would not require receptacles in a closet but since the NEC expanded the "AFCI requirement" to include wording devices & closet maybe it is an AHJ interpretation thing.
I would instead say that the NEC does not require receptacles in a closet, but if you choose to put some in they must be AFCI protected.
Growing up my folks would often have rechargeable flashlights and rechargeable 'dust busters' in the closet.
Like you when I think of a closet I think of a space I cannot get inside and do anything. However that is a narrow view, many closets now can be walked into, have vanity tables with mirrors, so I would fully expect anything from the aforementioned vacuum to hair dryers etc.
