E edward53 Member Jun 22, 2008 #1 I am trying to find the nec code that states the ground on the outlets is to be installed up verses down as it used to be.
iwire Moderator Staff member Location Massachusetts Jun 22, 2008 #2 The NEC does not require the ground up or ground down, that is entirely up to the customer, electrician or designer. Check out the FAQ on this. Should a receptacle be installed with its ground connection point up or down?
