chevyx92
- VA BCH, VA
Does a 240 volt recep installed outside need to be gfci protected? I say no...210.8(A) is my reasoning. Just want to double check. By the way its for a pressure washer.
Keep in mind that the receptacle will need to be protected from the pressure washer. Not even a NEMA-4 enclosure is designed to stand up to more than an ordinary garden hose.
