I have a question pertaining to an outside above ground 1000 gal diesel double insulated tank installation. The ultra-low diesel fuel will be the feed for a steam boiler located inside of a building. I am planning to run approximately 75 ft. of conduit from the control panel located inside of the building to the tank. I will be pulling low voltage control wiring that will connect to a tank level probe and an exterior jacket liquid alarm. Does the conduit have to be rigid and are there any other precautions I should be aware of?
