Re: outside ceiling fan
Tomz
Yes there are some specfic code referances for your installation
(2) Indoor Clearances. For installations in indoor pool areas, the clearances shall be the same as for outdoor areas unless modified as provided in this paragraph. If the branch circuit supplying the equipment is protected by a ground-fault circuit interrupter, the following equipment shall be permitted at a height not less than 2.3 m (7 ft 6 in.) above the maximum pool water level:
(1) Totally enclosed luminaires (fixtures)
(2) Ceiling-suspended (paddle) fans identified for use beneath ceiling structures such as provided on porches or patios
The key is identified for use, outdoor rated even on the enclosed porch
