Outside condenser and outside sprinkler pump circuits
Bassplaya
Cocoa
Does the 2p 30 amp circuit for the outside condenser have to be a dual function afci/gfci circuit breaker per 2021 code?
Does a 2p 20 amp circuit for a outside sprinkler pump have to be a dual function afci/gfci circuit breaker per 2021 code?
Tia
Good find.
That would mean residential wells, be they lawn sprinklers or not, require GFCI protection.
Is an outlet for a sprinkler or water pump utilization equipment?
You could say it is electromechanical. Is there an exception for utilization equipment?
Just curious, why would the 2020 NEC be a concern, Fl is under the 2017
Roger
