Is it required to ground the fence around air handling units?
Where in Code it is referenced?
That would only apply if the AC equipment is operating at a voltage that exceeds 1,000 volts. 250.190 is in part:Without additional information, 250.190 could be used to argue that the fence would need to be grounded.
2014
250.190 Grounding of Equipment
(A) Equipment Grounding. All non?current-carrying metal
parts of fixed, portable, and mobile equipment and associated
fences, housings, enclosures, and supporting structures shall be
grounded.
X. Grounding of Systems and Circuits of over 1000 Volts
