czars
Czars
- West Melbourne, FL
- Florida Certified Electrical Contractor
I can't recall if this has been addressed before or not, so here it goes.
I have an outside, fiberglass, hot tub that is mounted on a wooden deck. The bottom half of the tub is actually below grade, in the dirt. The wooden deck is above grade and the top of the hot tub rises about 12" above the deck. There are no electrical connections to the hot tub. Both the water and air are routed from the GFCI protected pump and blower, respectively, in PVC.
How does NEC 2008, 680.26 apply in this case?
