outside tankless gas water heaters on GFI's?
joecalvin
Austin Tx
Project and Purchasing Management
Guys, we have been running into issues with outside, wall mounted, tankless gas water heaters tripping the GFI breaker. The unit is hard wired with a switch for the disconnect requirement. the unit works fine on a standard breaker. The question is being this is a mounted stationary appliance/equipment do we need to have it on a GFI protected circuit? Has anyone else run into this issue with any brands of outside tankless gas water heaters?
Let me know.
Thanks
Let me know.
Thanks
Nothing requires a GFCI if it is hard wired. With a cord and plug connected unit having an outdoor receptacle is what will require GFCI, not the water heater itself.
