JohnJ0906
- Baltimore, MD
erm, usually range/oven circuits dont exceed 50 amps, and 8/3 romex is legal to use on a 50 amp breaker
(assuming that the breaker lugs and device lugs are rated for 75 degrees centigrade) (which there is a 99 percent chance that they are, based on what ive seen and read)
No it isn't. 40 amp max.
It is treated as a 60 deg conductor, although the 90 deg column can be used for derateing.
334.80
