I have an issue with a 3 PH 10HP 2 pole electric motor. With no load on this motor it is drawing close to maximum amps (13 to 15 amps). The application is a multiple stage water pump. I completely moved the motor from the pump and still drawing close to maximum current rating. The motor gets very hot to where you cannot touch the frame.
I always thought motor with no load draw about 35% of motor name plate rating?
Thank in advance for you input?
rmonroe
rmonroe
