I have designed lighting for commercial kitchens since 1970. In these kitchens, the minimum light lever in arras where food is prepared is 70 foot candles. However in residential kitchens it is almost impossible to find a light fixture that will mount under the wall mount cabinet that is often mounted over the kitchen sink, that will provide more than 15 foot candles and these are normally a 15-watt fluorescent with a circa 1940, normal power-factor, choke-type ballast with glow-lamp starters and with a plastic enclosure/lens that was designed for the 1940s homes. Today, compact fluorescent lamps, of various configurations are available up rated up to 45 watts, and the new electronic ballasts are available as instant-start, rapid start, and with dimming capability, high power factor, for single and multiple lamp installations, but none of the major light fixture companies offers in a light fixture for the kitchen sink that utilizes these lamps and electronic ballasts.
What I would like to find is the following:
Size: 24 to 30 inches wide, 10 to 11.5 inches front to back, up to 2-inches high.
Lens: Flat prismatic acrylic (A-12 or equivalent) 1/8-inch thick
Lamps: three (3) 4-pin 38-watt General Electric 2-D compact fluorescent lamp - 2395-lumens / lamp or other equivalent lamp
Ballast #1: 2-lamp electronic - Instant-start
Ballast #2: 1-lamp electronic - Instant-start
Switch: 4-position: 1) Off- 2) Connect to 1-lamp ballast, 3) Connect to 2-lamp ballast, 4) connect to both ballasts.
Mounting: To be mounted below the 30-inch wide, 12-inch deep wall mount cabinet above the kitchen sink, between the wall cabinets on both side of the sink and behind a wood fascia that matches the cabinets to shield the fixture from view.
Although I have sent drawing of this fixture to Lithonia, Day Brite, and other lighting fixture companies, none have even acknowledged my submittal and worse have not developed a fixture like this to light the kitchen sink adequately.
If you know of a light fixture manufacture that makes a high-output fluorescent fixture for the use noted above, let me know.
