I working on a concept here. Say I have a 1000HP 4160V soft start that has a load break disconnecting means THEN, as the manufacture calls them, 'motor protection fuses' immediately downstream. The fuses are not an integral part of the disconnecting means. The disconnect and the fuses are installed in the same gear but in seperate compartments, one above the other. The 1000HP soft start is the only load. This would be feed from an outside oil-filled transformer. I plan to meet either NEC 240.21(C)(3) or (4). Is there any issues with this?
What if I can't meet any conditions in NEC 240.21(C), would the disconnect and fuses of the soft start meet code? I'm trying to research what type of fuses are provided with the soft start unit but I haven't received this information yet. The fuses would be rated lower than the requirements in NEC Table 450.3(A).
