overcurrent protection for two motor loads
ejw
New member
idaho
Looking for calculation for my over current protection to feed two chiller motor circuits. Each chiller's MOC is 125 amps. Can I feed from 1 circuit breaker and use the tap rule to each disconnect using, 200 amp disconnects with 125 amp fuses, chiller 240v, 3ph. what size c/b do I need? and can I use 125 amp fuses as long as I use 150 amp conductors. {feeders 125%]??
