Hello
Is there any code reference/violation for a panel that has multiple subpanel feeds going out of it, if the panel has overcurrent protection on the line side ( main breaker)and has the proper wire feeding it? I know this is kind of confusing, but I really dont know how to word it correctly. A couple of examples:
A 200 amp rated QO panel feeding with 3/0 copper, feeding directly into a main lug breaker mounted in the panel. This panel then directly feeds five, 100 panels in a large residential home. I ran into this the other day. The installer has added the larger nuetral lugs accesories that mount directly on nuetral bars. three on one side, Two on the other. I guess this installation would act like a I line panel that you would see in a more commercial setting.
I cant find anything wrong with it in my code book. You have overcurrent protection and the nuetral bar is rated for the load. Any problems anybody can see??
Example 2
Combination meter main. Meter with a 8 space distribution panel in the same gear. This particular one is a homeline meter main. The combo distribution panel is fused with a 200 main breaker that feeds the buses. The electrian fed out the main lugs to the house with a 200 amp feeder, and then feed a garage with a two pole 100.
Again, pretty much the same thing. I guess I am not used to see high ampacity loads in residential gear like this. If the overcurrent protection is correct, I can't find any problems. Am I correct?
Thanks
Example 2
Thanks
