If you have a main distribution panel feeding a 1sub-panel with a 225amps breaker and than there is a next panel feeding from the 1sub-panel which is a sub-panel of 1sub- panel. Do that panel needs a overcurrent protection? If yes where should it be place? If no explain.
or
could you feed the last sub-panel from the logs of the 1sub-panel to the logs of the said sub-panel?
or
