Recently, I was asked to rewire a time clock ( 120v clock motor controlling two 120v loads )in parallel with a spring wound timer used as override and replace two of the three Class T fuses used as main protection for the panel ( 200a, 120/208v ). The person who asked me to do this wanted to know why the fuses opened and not the branch breakers for the two loads. MC cable was used as the wiring method so I'm assuming a short between grounded and ungrounded conductors. This being the case. Is it typical for a main fuse to go and not the branch breaker?
