electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
Hi,
We have an install where there are two structures, maybe 10-12ft apart, where there will be separate strings at each structure. I was wondering if I can run the DC string conductors overhead between structures? I was thinking to run conduit with a weatherhead at each structure and run free air sun/weather resistant wire from weatherhead to weatherhead. Any thoughts on code compliance with this proposition? No traffic will be driving under the wires and they will be over 12ft in height off grade, probably 14-16ft. It is a commercial install with 1000VDC max. Conductors will be XLPE 1KV.
Thanks!
Thanks!
