- Lockport, IL
- Semi-Retired Electrical Engineer
We have a project that will tap into an existing overhead distribution line for a new line that will be run underground alongside a street. The affected pole is presently being used to temporarily serve a nearby set of trailers. The installation contractor is telling us that the pole is ?too busy? (i.e., too many things on the pole) to be able to safely add our tap. They want to first relocate the line serving the trailers to the next pole, so as to make room for the new tap. I am no expert on overhead construction methods and safe practices, and neither is my co-worker.
Can anyone tell me, from looking at the attached photo, whether we (serving as the designer of record for the project) should concur with the contractor?s suggestion, or should tell them to go ahead and add the tap to the pole in its present configuration?
