Overhead fire door?
fayc11
plymouth ma
Good Morning,
Pharmacy in a hospital, 2 hour fire rated wall with a very thick bullet proof window with a hole in the center to talk and a slide thru to pass perscriptions thru.
Question...is there any requirement to have a overhead door to automatically come down when the fire detectors in the area happen to go off?
Any info or direction will be very helpful.
Thank you
Chris
Good Morning,
Thank you
Chris
Can't quote the chapter/verse, but the VA hospoital I do work at has an overhead fire door we connected to the new fire alarm system.
RC
Good Morning,
Thank you
Chris
Any opening in a fire rated partition requires an opening protective. It can be in the form of a fire rated overhead door or by other means.
There may be sprinklers installed to direct a curtain of water at the window in the event of a fire.
