elmundogrande
I had a family member call me about his panel after noticing it was warm and called his home warranty to have it checked. Someone came and checked and took the infrared reading see picture and told the homeowner they need to send a electrician. The electrician came and said it was okay and that the breakers can handle 186 degrees with out checking anything else. Any ideas that might be causing the heat other than a loose connection on the “A Phase” since it’s the only side of panel that is getting hot. Panel is in the house west wall insulated wall
