Dcash
New member
- Atlanta, ga
I have an issue with some lighting breakers. They are 3 pole breakers (20 amp), square D. These breakers are hot to the touch. Not alarmingly, but approx 100-106 degrees F. The client is very concerned about this, and even though derating is correct, wire sizes are correct, terminals are tight, and amp reading are between 12-14 amps, these breakers continue to be warmer than what I'm used to. The lighting load is T-5 fluorescents, 6-lamp. I haven't had this particular situation happen before. One or two circuits yes, but never EVERY breaker for all lights be this warm. Suggestions in case I'm missing something would be helpful. Thank you.
