What amount of ampacity (short circuit current) can an insulated #14 copper wire handle for a certain amount of time before there is damage to the insulation or the conductor itself? I'm looking for a Time vs Current curve that displays the information similar to the Time vs Current curves that manufacturers make for a circuit breaker to clear a fault. Example: At a short-cirucit current of 75 amps a typical 15A Cutler Hammer breaker should interrup the circuit current in approximately 6 to 7 seconds based on the Time vs Current curves for there specific breaker. But what I'm wondering, for what time duration could that #14 copper wire continue to heat up before the thermal limits of the insulation is damaged from the 75 amps? I'm sure wire manufacturer's have this information readily available. Please help. Thank you.
