Hi gang,
I need to add overload protection to a motor that includes switching controls (at the operator location). The equipment is moving and I need to conform with latest codes, which require such protection. (under CEC, I need this unless the motor has such protection built in, which it turns out that it does not. I expect NEC is the same rule).
Normally I spec a motor starter or overload relay for motors, with some kind of control system that switches them. Here, I need no control, just overload protection. Perhaps it is best and cheapest to simply wire a standard starter near the panel where the circuit originates, wired so it is always on (unless of course the overload trips)..?
thanks
thanks
