Overloaded as in voltage too high or current too high?Riyad said:Dear all, I have capacitor banks overloaded morethan 130% (as per IEC). What action shall I take?How to rectify?
Kindest regards,
Is the voltage at the correct level? If so, I would investigate harmonic contribution.Riyad said:Dear all,
According to IEC831-1, capacitors have permissible thermal current(RMS) of 130% of rated current. And what I have are of more than 130%.
If understood please, answer my question above?
Kindest regards,
Riyad
Riyad said:Yes,
. I noticed in some capacitors that even harmonics are more than odd ones.
ghostbuster said:Even harmonics are normally generated when the rectifier ccts(etc.) are not firing symetrically.I would recommend you check these circuits for non-symmetry operation.Correcting this firing problem should significantly reduce the cap overloading situation.![]()
