Are overloads required in a starter that is feeding a 3 phase heater? The heater is a 20kW heater. I dont think overloads are required since the heater load is a fixed resistance. I'm not sure what the NEC says about this.
In the starter there are 30A fuses and a #8 wire feeding the heaters. I'm guessing the heaters or cables dont need overload protection since the load is fixed. The 30A fuses then would provide short circuit protection for the branch circuit. Are the fuses alone adequeate protection?
I have a heater circuit that keeps tripping overloads (probably wrong size need to check). Instead of replaing overloads I was thinking about just removing them all together.
