vw55
- California
Assume a 300kVA transformer has been installed and the primary conductors and the transformer primary are protected and the secondary conductors and the transformer secondary are protected correctly for the 300kVA rating. Can the contractor simply reduce the size of the primary and secondary OCPD appropriate for a 150kVA rated transformer and use the 300kVA transformer as a 150kVA transformer as the load the transformer serves has been reduced? The installed primary/secondary conductor sizes will not be changed. Wouldn't the 300kVA transformer inrush current be a problem with the OCPD's?
