bgelectric
Which method would be most appropriate to shutdown the above mentioned systems during a fire alarm condition with a relay?
When you "shut down" the system, I would make sure it does not prevent use of the system for voice announcements. Unless there is a separate emergency notification system.Which method would be most appropriate to shutdown the above mentioned systems during a fire alarm condition with a relay?
Im assuming killing power would not be the best way to go about it.
