Hello All,
I wanted to see if there is anywhere else in the NEC that dictates the space requirements around a big green oil filled pad mount transformer.
110.32 says that the work space should be 36" wide and a depth as outlined in 110.34(A). From this I gather that no clearance is required to the left, right, and back of a pad mounted transformer, at least as per the NEC. Is there anywhere else in the NEC that requires some sort of clearance to the back and sides of pad mounted transformers?
Bonus question:
When are medium voltage transformers such as these:
https://www.hammondpowersolutions.c...ient-medium-voltage-distribution-transformer/
Used instead of big green pad mount transformers? Is it usually because of a utility requirement, or the requirement that the transformer be lockable and isolated from unqualified personnel.
Thanks for any input.
Bonus question:
