Hi,
We need to work on a main breaker of a 480V service. It's fed by a 12,470V -> 277/480Y pad transformer.
Typically (and per our safety policy), we would have the POCO pull the primary cutouts and ground the feeder on the pole that feeds the transformer or pull the loadbreak elbows on the transformer. In this case, due to downstream loads, the POCO wants to put the sectionalizing switch in the pad in the loop thru / transformer open position. We would then place LOTO on the door of the transformer.
Is the sectionalizing switch a reliable means to shut down the pad and suitable for this scenario?
Thanks.
Thanks.
