eds said:Working on a house that has a large master closet that shows a paddle fan in it. Closet is large enough that clearance issue can be met, pendant fixture is not really defined
How large is large in your neck of the woods??mdshunk said:A closet sufficiently large is no longer a closet.
stickboy1375 said:2008 finally gives a definition...
Just the right amout. No larger than normal. As large as necessary. That clear?quogueelectric said:How large is large in your neck of the woods??
gndrod said:Closet lighting is exempt if floor space is under 70sf. So, maybe a paddle fan stands on its own. rbj
