bjp_ne_elec
- Southern NH
Probably a dumb question, but I'm going to ask it anyways. Have a situation where the HO wants recessed lights in an average size room - roughly 11' x 11'-6". The HO does not like having lamps, so has insisted on having recessed lights - but the other thing in the mix is that they also want a paddle fan. I figured it best to put four (4) recess lights dividing the room up by thirds. The thing I'm struggling with is the proximity to the paddle fans.
The paddle fan (52" edge to edge on the paddles - seems like a pretty big blade span for a room this size) would not cover the actual edge of the recess can - but may infringe on part of the beam that is given off by each particular can. Would this create a sort of "strobe effect" on the small portion of the beam that may be "cut through"?
My concern is that if I were to move the lights more away from the center of the room, that I would get uneven lighting in the center of the room, than I had on around the perimeter. Has anyone ran in to a situation like this?
Thanks,
Brett
Thanks,
Brett
