rhawk111
New member
- Richmond,VA
We are currently in the process of installing new paint mixing equipment in an existing Class 1 Div 1 location. My concern is the touch screen monitor that comes off the Cpu has a standard cord plugged into it for its 120v power supply. There is also Cat 5 wire going back to the Cpu aswell as one leading to a scale. Do these cables have to be protected from the monitor to CPU which is outside this room in a safe location? Or can they remain as it shipped from the factory? The Monitor is XP proof and has proper labeling on its case. Secondly, the scale attached to this set up has low voltage power supply or transformer plugged into it? How is that code? Or XP proof at all? Yet again the case on the scale is XP proof. Thanks for any input!!
