wiremonkey78
Have you ever heard of a pan cake blank, and how would it be used in a LO/TO situation such as this language describes below. This is from a proposed ANSI construction standard on LO/TO:
2.8 Energy Isolating Device
A verifiable mechanical device that physically prevents the transmission or release of energy, including but not limited to the following: a pan cake blank, a manually operated electrical circuit breaker, a disconnect switch, a manually operated switch by which the conductors of a circuit can be disconnected from all ungrounded supply conductors and, in addition, no pole can be operated independently...
