I have to install six lighting fixtures in six rooms. The existing ceilings were gone over with 1/2" drywall witch set the octagon boxes in 1/2"+. With multiple wires and the box connectors the box's won't shim down with out surgery to the ceiling. I never saw a 1/2" box extension for an octagon box so my bright idea is to use a pancake box as a box extension with a rubber bushing for the conductors to pass through. Also the house wiring is NMB and if I splice on 90 DEG NM conductors in the octagon box it might comply with the 90 deg requirement for new fixtures. Most of the inspectors in my area tend to ignore the 90 deg conductor requirement. As far as I can see in the articles in 314 (2005 NEC) this idea might be OK.
Would welcome some pros and cons on this. Thanks
