Got a job today, moving a 200 amp main panel and a sub panel from a exterior perimeter finished basement wall to a central interior finished basement room. Aproximately 60/cirft inside. We will be installing the required main outside and then rendering both panels into sub panels via four wire cable and ground kits..The HO will be relocating all of the home runs as the basement is under construction...
But my issue is... pulling future circuits will be impossible as they will be un-accessible after everthing is sheetrocked.
I've never heard of any code requirements to provide access or chase's for future circuits. Is there such a thing? If not I think there should be...I know of one EC in town that installs a empty 1" pvc chase up into the attic on every new resi wire...Im going to suggest that HO has us put one in to a more accesible location.
