Mongo1953
- Didsbury, Alberta
I have a customer who had a home inspection done. He has a 1978 vintage Westinghouse GLC 24 100 amp combination panel. All his branch cct wiring is aluminum. The home inspector noted in his report that the panel MAY not be rated for use with aluminum wiring. I could not spot anything on the panel indicating one way or the other. The breakers are CU/AL, but the concern is the rest of the panel. Does anybody know if that panel is CU/AL or where I could find out?
Thanks
Thanks
