McLintock Senior Member Location USA Occupation Electrician Mar 31, 2022 #1 Do not have code book with me right now, is there any volition with putting a panel behind the door(when the door is open) of a bedroom? We are on 2017 code Sent from my iPhone using Tapatalk
R rc/retired Senior Member Location Bellvue, Colorado Occupation Master Electrician/Inspector retired Mar 31, 2022 #2 Not a problem Ron
N norcal Senior Member Mar 31, 2022 #3 Quite desirable as not going to have debris piled in front the panel limiting access.
4x4dually Senior Member Location Stillwater, OK Occupation Electrical Engineer/ Ex-Electrician Apr 1, 2022 #4 Not at all. You can even put meters behind there is you cut access holes.
