ironphill
- Conroe, TX
OK, I've got a new one. I was wiring a panel a while back and it was a siemens with no ground bar. Instead of going to buy a new ground bar, I put the grounds on the left neutral bar, the neutrals on the right, and even though it probably wasn't necessary, moved the bonding screw to the left side with the grounds and screwed it tight. I also left the copper bar that bonds the 2 neutral bars together in place. Well, an old school electrician was trying to tell me that it was wrong because it was "too good of a bond" between the grounds and neutrals. He said that the only right way to do it was with a ground bar. I'm not trying to slam the dude because he's a good electrician, I just want to make sure I'm not crazy here.
